Will my build cause bottleneck
Jgro1413
4
So Currently my pc build is as follows:
-AMD Athlon X4 860K Kaveri Quad-Core 3.7 GHz
- ASUS A68HM-K FM2+ AMD A68H FCH (Bolton D2H) 4 x SATA 6Gb/s port(s), gray USB 3.0 Micro ATX AMD Motherboard
- ADATA XPG V1.0 8GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model AX3U1600W8G9-RR
-Rosewill Stallion Series RD500-2SB - 500-Watt ATX12V v2.2 Power Supply
-XFX R7 360 2 Gigs GPU
And my question is if I purchase the sapphire r9 390 (http://www.newegg.com/Product/Product.aspx?Item=N82E16814202164&cm_re=r9_390-_-14-202-164-_-Product#close) will my other components be able to handle it? Any advice helps, thanks guys. And also if it isn't able to support that card would buying a better PSU with more watts help me be able to use it? Thanks guys and gals
EDIT: Also I've had issues trying to record me playing video games such as ark evolved, if i were to buy a better gpu would this help with how choppy it is or is that issue related to my cpu?
EDIT: What aboout the r9 380
This page shows you that on low end gpu builds, the gpu is the bottleneck. Sure a better cpu will give it a few more fps, but it is better to invest in a better gpu. The 380 will be bottlenecked. I can not say how many fps you will lose with an 860k or kavari, but the kavari is a better cpu. You will be able to play demanding games and screen record. Also 500 watts is enough.
http://www.pcper.com/reviews/Systems/Quad-Core-Gaming-Roundup-How-Much-CPU-Do-You-Really-Need
380 Benchmark: http://www.gamersnexus.net/hwreviews/1984-amd-r9-390-380-benchmark-review/Page-2
