Will my build work?
makahu
5
I'm building my first pc and these are the specs i have chosen. i just want to know if they are compatible and what kind of cooling system i should get?
Case: Antec 1100
Processor: Intel i7 4770k 3.4GHz Socket 1150
Mobo: Gigabyte GA-Z87-HD3 socket 1150
PSU: Corsair TXM 850W modular
RAM: 2x Predator 4GB 1600MHz DDR3 CL9 DIMM
HDD: 2x seagate 1TB Barracuda 3.5
Perhaps he doesn't care about graphics (like I don't) and he just wants raw computation power so the integrated will be just fine.
ANd yes 850Watt PSU is a bit too much. And if you are not using a dedicated graphics card then its enough for LN2 applications.
One note. Ditch one seagate HDD and get a Samsung 840 Pro 256GB for system disk in order to have a proper rig.
Sorry, the GPU im going to use is Gigabye GTX 670. Well i asked my friend who has done a build before how much wattage i should use and he recommended that one. I basically need a powerful pc for animating and hardcore gaming
thanks. i wasn't sure if i should switch a HDD for a SDD but most sits seem to recommend i do that and install my OS onto it for a faster boot up?
thanks. If its not too much trouble to ask, will this build be able to do massive renderings or would you recommend any different components?
how much more? my budget is £1200 excluding monitor, cd drive etc
It will blow your budget. http://uk.pcpartpicker.com/parts/partlist/
