J Joseph_145 Commendable Dec 11, 2016 56 0 1,630 Dec 12, 2016 #1 Can someone tell me if the case in my build can make everything fit in it and work perfectly.
Solution B B boostedturbo Dec 12, 2016 go to pcpartpicker.com and enter your case and the build... it will tell you if everything is compatible and if it will fit inside.
B boostedturbo Commendable Dec 9, 2016 83 0 1,660 Dec 12, 2016 Solution #2 go to pcpartpicker.com and enter your case and the build... it will tell you if everything is compatible and if it will fit inside. Upvote 0 Downvote Solution
