A Alexy_ Commendable May 14, 2016 75 0 1,630 Aug 19, 2016 #1 Will everything fit into NZXT H440 case by Razer?
Solution Xemko Aug 19, 2016 Yes, everything will fit. https://www.nzxt.com/products/h440-white . GPU Clearance With HDD Cage: 294mm GPU Clearance Without HDD Cage: 428mm CPU Cooler: 180mm
Xemko Admirable Feb 15, 2015 1,714 1 6,960 Aug 19, 2016 Solution #2 Yes, everything will fit. https://www.nzxt.com/products/h440-white . GPU Clearance With HDD Cage: 294mm GPU Clearance Without HDD Cage: 428mm CPU Cooler: 180mm Upvote 1 Downvote Solution
JBeard Honorable Jul 7, 2016 57 0 10,660 Aug 19, 2016 #3 The case is a Mid-Tower so should fit those components nicely. I'm not sure if you have, but make sure you do the free upgrade to the 850w power supply, probably better for this rig and future proofing too. Goodluck. Upvote 0 Downvote
