Will my computer build work (Links)[Urgent]
I don't think that ram will work with that motherboard, and if you want to get the most out of your 780, you will NEED a PCI-E 3.0 slot, this one is PCI-E 2.0. It should work for everything apart from the motherboard. If I was you I would swap your motherboard out for something bettter. maybe a MSI-Z87-G43 GAMING motherboard. It will be alot better for your build. Best of luck.
