Hey there! Not a PC noob but just need a little bit of advice on something.
My current build is running:
i7-10700K
RTX 3070
32GB DDR4 @3200mghz
on a Gigabyte Z590 Motherboard.
I want to get a new GPU and I'm looking at the RTX 4070. Money is not the issue it's mainly just the pain of replacing parts. I don't want to have to replace both my CPU and motherboard to be able to use a 12th gen CPU (since i prefer intel) and my motherboard only goes up to 11th gen. So I figured I would ask if my CPU will bottleneck the 4070 too much or if I need to upgrade both my motherboard and CPU. Either way I'm getting the new GPU, I just don't wanna go through the hassle of replacing both of those things along with it.
thank you!
i7-10700K
RTX 3070
32GB DDR4 @3200mghz
thank you!
