T ToxicHydra Reputable Aug 22, 2014 22 0 4,510 Nov 1, 2014 #1 Would the be quiet! dark Rock 3 fit in the Aerocool X-Predator X3
Solution rolli59 Nov 1, 2014 Yes the case supports up to 186mm high coolers if you take the fans off so it will do 160mm with the fans in.
rolli59 Titan Oct 27, 2007 47,805 285 130,890 Nov 1, 2014 Solution #2 Yes the case supports up to 186mm high coolers if you take the fans off so it will do 160mm with the fans in. Upvote 0 Downvote Solution
T ToxicHydra Reputable Aug 22, 2014 22 0 4,510 Nov 1, 2014 #3 rolli59 : Yes the case supports up to 186mm high coolers if you take the fans off so it will do 160mm with the fans in. Thank you Upvote 0 Downvote
