Will my CPU work with this Motherboard?
awhile that motherboard is compatible with that 3rd gen CPU, the H61 chipset originally came out with 2nd generation intel CPU's so it possible it may need a BIOS update out of the box for the CPU to work with it
to avoid this problem get the model number of the CPU and check on MSI's webpage to see what BIOS version is required for that CPU to work then contact the seller and ask what BIOS version is on the board.
I will be able to update the BIOS myself though if I run into this problem?
unless you have a 2nd gen CPU you can install in it then no. you have to get the computer to boot first in order to update the BIOS. contact the seller to see if they will update the BIOS to the latest for you
