View: https://imgur.com/a/5EDEuet
https://uk.pcpartpicker.com/user/LewisMann/saved/#view=8Nvn7P
Hi, I am looking at buying a new CPU, Motherboard, and RAM, to upgrade my current system. I have attached links above to the new system I am going to be buying; Should I be worried about the message in the imgur link where it says the compatibility notes? The "worried" meaning will I have to buy anything certain to fit anything together or if some parts are just not compatible. If so, please could somebody recommend me some new parts to my system apart from the CPU, I would like to keep the Ryzen 5 2600 as my main part. I currently have in my computer now, the Corsair H105 as my liquid cooling. Basically, overall I would just like to know if my new parts (CPU, motherboard, and RAM) would be compatible with this liquid cooling! Or if I would have to find some mounting brackets etc.
My current system is:
GPU:MSI GeForce GTX 1060 Gaming 6G
CPU: AMD FX-6300 @ 3500mhz
RAM: Kingston Hyper X Fury DDR3 1866mhz
Power Supply: Corsair CS650M
I would appreciate an answer, thanks
