thanks a lot!Yes, the Matrexx 55 can take up to a 360mm radiator in the front and a 240 will fit perfectly up top. This cooler is compatible with AM4.
The number of fans included should be in the full product listing name. For example, if your case has a "3f" at the end of it, it'll have 3 fans included. "4f" will come with 4 fans and so on. If it does not have this at the end, then it does not include fans. I hope this helps!thanks a lot!
Do you also know if I need to buy extra fans for the case?
just received my case, there are no fans in thereThe number of fans included should be in the full product listing name. For example, if your case has a "3f" at the end of it, it'll have 3 fans included. "4f" will come with 4 fans and so on. If it does not have this at the end, then it does not include fans. I hope this helps!
Now you can select any kind of fans you like!just received my case, there are no fans in there
what do you think about these? How many do I need?Now you can select any kind of fans you like!
