Will my first build turn on?
MyOhMyers
4
I have already ask the community for suggestions and I've compiled a part list of my future first build. I just wanted to make sure everything looks good and It's going to turn out to be a pretty good gaming computer. Feel free to give suggestions, if needed. Thank you
http://Partlist
my personal choice would be gigabyte model of r9 270x and if u want a mini itx case corsair obsidian is what i will suggest its more spacious than the prodigy and have way better airflow....and other components are looks good ... :)
I'd go with i5 4690k if you can find it for about the same price as the 4670k. Also maybe some 1866-2133mhz ram instead of 1600, as haswell really scales well on fast ram. Last, consider getting windows 8.1 instead of 8, not sure if the upgrade is still free. Aside of that, that rig is going to be pretty beastly, even though I can't say much about the gpu (not familiar with amd cards). 😉
