Will my gpu fit in my case?
TheRealDJDuckVenom
Commendable
Dec 10, 2016
61
Hi there,
I know this is a nooby question, but I just want to triple check. Will a GTX 1060 6GB D5 from Gigabyte fit in a Corsair 100r case without removing the drive bays ( I will be using the top PCI-E slot) It looks like it will fit by looking at the specifications and the picture, but I just want to make sure.
Any help is appreciated :)
the size of the gpu you can ut inside in the case is determined by the case manufacturer, if the manufacturer in this case, corsair, says that it can fit in this case
http://www.corsair.com/en-eu/carbide-series-100r-mid-tower-case
Maximum GPU Length: Top Slots: 414mm, Lower Slots: 275mm
since you report that you are buying 1 gtx 1060, this one
http://www.gigabyte.us/Graphics-Card/GV-N1060D5-6GD-rev-10#kf
Card size H=40 L=278 W=114 mm
it says length 278 millimeters, it should be enough of room for the power cable there then and for the front fans for that case if you install it in the first pci express x16 slot
if your motherboard has more pci express x16 slots it seems that on your case you can't install it there so use only...
if your motherboard has more pci express x16 slots it seems that on your case you can't install it there so use only one gtx this size on the first slot and you should be fine
btw, you are buying a case without a window on the left panel but your gpu is meant to be showed trough a window, for the leds and fan indicators, consider buying a case model with a window on the left panel or see if you can find a panel with window for the 100r you chose
Thanks Mate. My case does have a windows, you might of clicked the silence edition witch doesn't have a windows but is the exact same
