Will my GPU fit into my motherboard?
forsberg
I have noticed the gpu I want is larger than the original 1080ti, and im wondering if that means it will be too big to go into my motherboard.
GPU: ASUS ROG STRIX 1080Ti
Motherboard: Asus ROG Maximus IX Hero Z270
GPU's use the same standard, utilizing a PCIe x16 slot - so it'll "fit" in that sense.
You may run into compatibility issues with your case though, with longer GPUs.
