Will my GPU fit my Case - drive cages
folodarolo
87
Hi I have purchased a Sapphire Tri-x OC for my first build - http://www.sapphiretech.com/presentation/product/?cid=1&gid=3&sgid=1227&lid=1&pid=2072
I am looking at the NZXT Source 530 ( http://uk.pcpartpicker.com/part/nzxt-case-caso530m1 ) which can give me 444m of space without drive cages but only 282mm with them which is obviously too small. I have an SSD (Samsung EVO 250gb) and a HDD (WD 1tb Cavier blue)
What I'm wondering is, is there any way to take out the other modular drive cages not being used and leave enough space for my GPU to fit or is this recommended/possible?
The middle HDD cage module can be remove allowing you to install graphic cards with a length of up to 444mm.
There is a 2nd HDD cage module on the bottom that can be used to install a SSD and HDD
http://www.nzxt.com/product/detail/137-source-530-full-tower-computer-case.html#
I know this is off topic but could you guys give me some advice on what type of case fans I should put in my build (if I decide to go for the case I mentioned). Here is a quick 3 minute video from NZXT about the case and showing the fans positions - https://www.youtube.com/watch?v=BtBMljG0lRc
My thoughts so far:
Front - Two 120mm intake fans
Bottom - Two 120mm intake fans
Rear - One 140mm exhaust fan
Top - Two 140mm exhaust fans
Any thoughts/suggestions?
What fan should I buy for the rotating fan that is in the case and will this interfere with my GPU?
Here is my build: http://uk.pcpartpicker.com/p/pQYQwP
Do I need a fan controller or can my case & mobo control and do most of what the fan controller does?
I would appreciate any advice, thanks.
