Will my graphics card and power supply fit in this pc
westonbezzant
5
I have what I believe is a Dell Inspiron 3847, but I could be wrong. (If anyone knows how to check what a PC is called, then pls comment that) Anyway, it has a 300 watt psu and I'm looking to upgrade that as well as my graphics card. Will they fit? If you need a pic of my pc, I will post it.
PSU: https://www.amazon.com/gp/product/B00H33SFJU/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1
Graphics Card: https://www.amazon.com/gp/product/B01M6ZF3LC/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
Edit: So is this too big?
The dimensions say 11.2 x 5.7 x 1.3 inches
The 'drive cage' is that metal framework that the HDD is sitting in. The max length of card you can use is what will fit as measured from the back of the case where the expansion slot covers are to that cage... obviously.
Btw, you may not need a new PSU if the one you have now is a 300W Dell unit. Most can handle the GTX 1050. Even the faster GTX 1050 Ti which isn't much more. And as long as you settle on that short mini card, you have plenty of room.
Look at the nameplate on that PSU. Let me know what it says. I might be able to...
Look at the nameplate on that PSU. Let me know what it says. I might be able to help you get a faster card and not have to upgrade the PSU.
