will my graphics card fit in
nneewwuusseerr
31
Hi i m interested in Thermaltake View 28 RGB Ring Cabinet.My question is,will my asus strix 1080ti fit in?
Cabinet spec says:
"CPU cooler height limitation:155mm
VGA length limitation:410mm (Without Front Fan)
*Suggested VGA thickness up to 40mm(2-slot reference card standard) with 7mm space for ventilation if extending for VGA card".
Gpu spec says:
298 x 135 x 53 mm
This is a 2.5 slot card.
I dont understand what word "extending" means here.This cabinet support vertical gpu placement with a gpu riser.So maybe word "extending" is for that.
help plz.thanks.
Yea that's for 2 slots. You can always just remove another piece and have 3 slots. Like I have with my 1080ti Aorus.
Unless you're using the bottom black slot, I am too lazy to read the details on your motherboard but you probably have those 2 above that are PCIE 3.0 x16 so you're fine. Just make sure you put it in well so it doesn't move or bend.
Judging by the size of that case, yes it will fit in.
The only way it will not fit, is if you have a retarded motherboard that somehow places your GPU slot very low and thus will hit the bottom of the case. But considering most motherboards, it will fit 99%
my mb is x370 msi gaming pro carbon.
and then why this *Suggested VGA thickness up to 40mm(2-slot reference card standard) with 7mm space for ventilation if extending for VGA card".
And my card thickness is 53 mm.
