Will my graphics card fit?
Veyron1775
So I'm buying an msi 980 ti lightning edition and was wondering if it would fit in my case. I have a corsair vengeance c70.
I'm afraid not.
From the case website:
Maximum GPU Length = 320mm
From the GPU website:
Card Dimension(mm) = 330 x 140 x 53
**The maximum GPU Length stated above MIGHT be assuing that you have the drive cages installed. If you don't have any front drive cages there is a possibility that you could fit the card. You'd need to do some measurements on your own to verify.
I'm afraid not.
