Will my graphics card work with 3 monitors?
NVIDIA Surround with Up To Four Monitors Nothing is as breathtaking as playing your favorite games across three monitors. At 5760 x 1080, the expanded field of view fully engages human peripheral vision and provides for the most immersive experience in racing and flight simulators. Add in a fourth display to keep tabs on chat, email or web while you are gaming.
No, a single card will struggle with three monitors.
What you want are two cards in SLI - and because of the extreme resolution you're using, you need them to be high in VRAM.
What that would mean would be two 4GB 680s... but the 680 sucks anyways.
So get two 4GB 670s instead - the 680 is only 5% faster, which is NOT worth another $100.
army1506
99
Well then i might just reconsider getting 3 monitors, seeing even if i got the 670's (4gb), it would cost me almost 900 dollars for a SLI set up.
Would it really be necessary to get two 4gb 670's? I would figure if i had two cards in SLI, that were 2gbs each, id be getting 4gbs overall. Or would i need that much VRAM to game these 3 monitors?
Would a 680 4 gb be able to handle these three monitors, or would i still be stuck getting two for SLI?
army1506
99
Im in the middle of my computer build. I just dont want to go out and get 3 monitors, and get one 680 and then realize im going to have to get another one and have to come up with another 469.99 just to be able to game on my monitors. Thats why i wanted to ask before i buy graphics card and get stuck buying another one.
army1506
99
So do you think ill be safe going with one 4gb 680 running three monitors? ( i really dont have enough for two 680's at the moment)
That's more than reasonable, my question was directed at DarkSable though because of some nonsense that he's posted in other threads.
army1506
99
Ohh alright. But by the way, like i asked the other person, do you think if i upgrade to a 4gb 680, will it work better than a 2gb 680? What i mean is, will the difference be night and day, or will the difference not be worth another $100?
If you are intending to go multi monitor then more Vram is usually recommended but I can't say for sure as I only game on a single monitor.
