K Kiran_15 Commendable May 13, 2016 1 0 1,510 May 26, 2016 #1 Please Help Me.I bought powercolor r7 250 1gb ddr5 graphics card.now i realise it reqiure a 6 pin powercable. I dont have on in my smps.Please help.will it work without a powercable or will i need a new smps.
Solution SniiKz May 27, 2016 It could be an older powersupply, but still have enough voltage to power it? Just a temporary usage.
DustinV Honorable Dec 22, 2015 1,620 2 12,465 May 26, 2016 #2 Better option, return the r7 250 and get a Gtx 750 ti that doesn't need a power cable And no the gpu won't work without power Upvote 0 Downvote
SniiKz Reputable Mar 30, 2016 110 0 4,710 May 26, 2016 #3 You could try using a molex to 6-pin connector. Upvote 0 Downvote
DustinV Honorable Dec 22, 2015 1,620 2 12,465 May 26, 2016 #4 SniiKz : You could try using a molex to 6-pin connector. bad idea, if the psu doesnt have a 6 pin connector it isnt made to power a gpu. Upvote 1 Downvote
SniiKz Reputable Mar 30, 2016 110 0 4,710 May 27, 2016 Solution #5 It could be an older powersupply, but still have enough voltage to power it? Just a temporary usage. Upvote 0 Downvote Solution
