Super_11 :
chalky16 :
Super_11 :
chalky16 :
It should but I'd say you should just save more money and upgrade your system as a whole
im saving reigh now but before i build new pc i want to play newer games.For now i have only bought gtx 1050
If you do get the 1050 get another 4 gb of RAM or else you won't be able to play new games very well.
My new pc would be with 8 GB DDR4 ram
so is my GTX gonna run on this system
It will run but not very well the CPU will be a bottleneck as it not the best. If you could save the money you could get a Kabylake or Skylake i3, 4GB more RAM with a budget LGA 1151 Motherboard. you should have a decently capable gaming system. There is no compatibility issues with the CPU, MoBo and RAM it is just the RAM and CPU will be bottlenecking the GPU's full power in games.
Hope this helps,
Niall
