S stefanos18pc Reputable Sep 7, 2014 62 0 4,630 Sep 13, 2016 #1 Hello guys.I ordered the MSI H170 GAMING M3 RETAIL .its an atx motherboard will it fit on my case which is aerocool strike x one advance?thanks in advance
Solution Dark Lord of Tech Sep 13, 2016 Your case supports. Motherboards :Micro ATX/ATX Your all set. 😀
C Chugalug_ Titan Jan 28, 2016 16,502 4 74,965 Sep 13, 2016 #2 Yes it will fit, there is plenty of room. Upvote 1 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Sep 13, 2016 Solution #3 Your case supports. Motherboards :Micro ATX/ATX Your all set. 😀 Upvote 1 Downvote Solution
S stefanos18pc Reputable Sep 7, 2014 62 0 4,630 Sep 13, 2016 #4 Chugalug_ : Yes it will fit, there is plenty of room. Thank you very much...i can sleep with a big relief now. Upvote 0 Downvote
