Will My MoBo Support 4 Pin Fan splitters For Corsair LL series Fans?
GraemeB6723
Greetings. I'm hoping someone here can answer a question I have.
I recently purchased four Corsair LL RGB fans ( One 140mm & Three 120mm fans) and realized my Gigabyte G1.Sniper B6 motherboard only has 3 4pin fan outlets on it. Thus making me unable to hook up all of my fans. Now I'm thinking about purchasing some fan splitter cables in order to hook up all the fans and two possible 140mm Corsair LL RGB fans down the line. The splitters I was looking at had a warning at the bottom which stopped me from making the purchase right away:
Caution: common mainboard fan headers support up to 9.6 or 12W (check your mainboard manual for detailed information). Therefore please make sure that the combined power draw of the fans connected to one fan header using NA-YC1 adaptors does not exceed this value!
Here is a link to the splitters: https://www.amazon.ca/noctua-NA-SYC1-green-NA-SYC1-chromax-green-y-cables/dp/B07656YTT9/ref=sr_1_5?rps=1&ie=UTF8&qid=1515534458&sr=8-5&keywords=4+pin+fan+splitter
Here is a link to my current MoBo: https://www.gigabyte.com/Motherboard/G1Sniper-B6-rev-10#ov
Just wondering if I the splitters and MoBo can work together and can do this or not? If there is another solution possible please let me know as I'm pretty much new at this sort of thing and don't have much knowledge on the subject.
Any help would be greatly appreciated.
GraemeB6723
Thanks for the answer. I bought the triple pack and it came with the lighting node pro So I'm good to go.
