N n8tehgr8 Honorable Oct 12, 2012 16 0 10,510 Oct 13, 2012 #1 Hey. I was wondering if this motherboard would be able to handle my GPU and CPU. ASRock H77M LGA 1155 Intel H77 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard Core i3-3220 Sapphire Radeon 7870 GHz Edition OC Thanks!
Solution AstroTC Oct 13, 2012 Yes, I see know reason why it shouldn't run your components. The H77 is more than enough for a budget build
AstroTC Distinguished Oct 31, 2010 347 0 18,810 Oct 13, 2012 Solution #2 Yes, I see know reason why it shouldn't run your components. The H77 is more than enough for a budget build Upvote 0 Downvote Solution
N n8tehgr8 Honorable Oct 12, 2012 16 0 10,510 Oct 13, 2012 #3 AstroTC : Yes, I see know reason why it shouldn't run your components. The H77 is more than enough for a budget build Thanks! Upvote 0 Downvote
N n8tehgr8 Honorable Oct 12, 2012 16 0 10,510 Oct 13, 2012 #4 Best answer selected by n8tehgr8. Upvote 0 Downvote
AstroTC Distinguished Oct 31, 2010 347 0 18,810 Oct 14, 2012 #5 You are very welcome Upvote 0 Downvote
