Will my motherboard come with a built-in speaker?
Abdullah0011
Commendable
Mar 24, 2016
I am about to buy a GIGABYTE GA H110M DS2 motherboard.
I just wanted to know that does this motherboard come with a built in speaker?
I bought a used case to save money, and I did not receive any speaker with it.
Is it really important to have one? Or does my motherboard come with a built-in speaker?
Most motherboards will have a speaker but it's only a tiny item and just designed to give an audible BEEP if things are going wrong in the system.
Your board will have an audio functionality with sockets for a microphone and speakers.
GIGABYTE GA H110M DS2 does not come with a built-in speaker. New bare PC cases often come with a Motherboard Case Internal Speaker.
http://www.newegg.com/Product/Product.aspx?Item=9SIA2RP0YW4962&Tpk=9SIA2RP0YW4962
(page 15 of downloadable manual)
F_PANEL (Front Panel Header)
Connect the power switch, reset switch, speaker, chassis intrusion switch/sensor and system status indicator on the chassis to this header.
