Question Will my motherboard work with an RTX 2070 or RTX 2080
ghozt67
Commendable
Oct 23, 2018
27
If said gpu has a thick backplate, the motherboard's ram clips will get in the way and the gpu will not fit. And if the card is long, it might not fit in your case. Try to look for gpu models that are well suited for itx boards. Now should you be able to find a suitable card, it will work functionality-wise.
