Will my new build work? First time build
Gaymur
8
Hello, this is my first build and I'm still way open to suggestions. I plan on gaming with this PC as well as daily use movies/web. Not only is this my first build but my PC (hardware) understanding is not that great, though has improved greatly over the last few days. So I guess what I really am asking is, is this all compatible? and is it a solid gaming setup? Thanks in advance for any input
-Corsair Carbide Series 500R
-EVGA 02G-P4-2680-KR GeForce GTX 680 2GB
-Intel Core i5-3570 Ivy Bridge 3.4GHz (3.8GHz Turbo Boost)
-ASUS SABERTOOTH Z77 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
-Western Digital WD Black WD2002FAEX 2TB 7200 RPM SATA
-ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner
-G.SKILL Ripjaws X Series 8GB 240-Pin DDR3
-CORSAIR HX Series HX850 850W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire
-CORSAIR Hydro Series H60 (CWCH60) High Performance Liquid CPU Cooler
-Kingston HyperX 3K SH103S3/120G 2.5" 120GB SATA III MLC Internal Solid State Drive
Looks like a very good build. You sure you don't want the unlocked 3570K processor? You went with liquid cooling and a z77 boards so something tells me you had overclocking in mind.
Yeah, you want the processor ending in "K" for overclocking.
Also, that h60 isn't really that high performance. You will probably get higher overclocks with a beastly air cooler that cost the same.
Yes, thank you for that, I know have it on my to buy list. I guess I was under the impression that liquid cooling would be the best. what would you recommend as far as air cooling?
