Will my new monitor work well w/ a 512MB GeForce G310?
Hi.
I'm not gaming. I'd use the monitor for movies, photoshop, lightroom, ableton live, premier pro and web browsing until I upgrade my PC.
Thanks
I personally wouldn't cancel the computer you have coming! Because since the resolution of that monitor is so high you may run into problems! What kind of processor?
Hi
I currently have a Core i5 3.20GHz processor.
I would not use the monitor with your GPU you have at the moment! The GTX 650 will handle it well!
I see 🙁
Thank you for your help. I'll try to keep my order for the new computer I configured on HP's website. It has a i7-6700K processor.
Take care.
That's actually a good bulid for an HP the GPU and CPU should go fine together! Also enjoy that monitor! 😀
