If I had the Noctua NH‑D15 air cooler and the Phanteks Enthoo Pro ATX Full Tower case, would I be able to overclock the i5 6600k to 4.5ghz (voltage will be anywhere between 1.23-1.29 depending on the stability) with good, stable thermals? Or would I need to add better and/or more fans to the case? Or would I need to get even a better CPU cooler?
Planned Build: http://pcpartpicker.com/list/FqCY9W
Thank you in advance for the help!
