Will my parts fit in the case I want to buy?
GrahamSlam
Commendable
Sep 9, 2016
Hi there!
So this is my first time making a pc. I've got a pcpartpicker build listed out:
http://pcpartpicker.com/list/sTwz6X
My main concern is buying a case that's able to fit all the parts I need. I'm not sure if the Corsair Spec-02 has enough room to fit everything. Would it be smarter to build a PC in a full tower rather than a mid tower? If so, what are some of your guys' recommended cases that would be good to build with? Budget is between $1200-1400 (if that's important). I'm also slightly concerned I won't have enough PCI slots on the motherboard to fit everything I want. Wireless network adapter isn't necessary, but would be nice to have rather than a dongle.
Any help that can be provided would be nice! Thanks in advance!
Well you might change the case. There is a chance that hyper evo could touch the side panel in spec-02.
Some of the people say they barely fit it, other say that it touches the side panel.
I guess depends from case to case.
If you look @ official company statements, it should not fit since evo is 159mm and case holds 157mm max.
Do you want side panel to have window or ?
Are you thinking of watercooling and do you need 5.25" bays ?
I don't need a window for the side panel. And no watercooling. Not quite sure about the bays. Most likely not.
