S SantaOnRs Reputable May 31, 2014 175 0 4,710 Jun 28, 2014 #1 I am in the process of picking parts for my new PC that I will be building later this year and I was wondering if the vantage gamers case will be able to fit all of these parts; http://uk.pcpartpicker.com/p/kG8tK8
Solution IRONBATMAN Jun 28, 2014 Assuming that this is the case you are referring to http://www.amazon.co.uk/CiT-Vantage-Gaming-Audio-Reader/dp/B0071KZNUY I think all prts should fit, but i'm not toos ure about the CPU cooler. I could not find any real specs for it
freeracercolin Honorable Nov 13, 2013 316 0 10,960 Jun 28, 2014 #2 Yes, it should all fit and play nice together. Upvote 0 Downvote
IRONBATMAN Honorable Aug 30, 2013 3,359 0 13,460 Jun 28, 2014 Solution #3 Assuming that this is the case you are referring to http://www.amazon.co.uk/CiT-Vantage-Gaming-Audio-Reader/dp/B0071KZNUY I think all prts should fit, but i'm not toos ure about the CPU cooler. I could not find any real specs for it Upvote 0 Downvote Solution
S SantaOnRs Reputable May 31, 2014 175 0 4,710 Jun 28, 2014 #4 freeracercolin : Yes, it should all fit and play nice together. IRONBATMAN : Assuming that this is the case you are referring to http://www.amazon.co.uk/CiT-Vantage-Gaming-Audio-Reader/dp/B0071KZNUY I think all prts should fit, but i'm not toos ure about the CPU cooler. I could not find any real specs for it Okay thanks, I'll have to look around and find out if it'll fit;D Upvote 0 Downvote
S sora Splendid Oct 30, 2013 7,812 0 31,460 Jun 29, 2014 #5 SantaOnRs : freeracercolin : Yes, it should all fit and play nice together. IRONBATMAN : Assuming that this is the case you are referring to http://www.amazon.co.uk/CiT-Vantage-Gaming-Audio-Reader/dp/B0071KZNUY I think all prts should fit, but i'm not toos ure about the CPU cooler. I could not find any real specs for it Okay thanks, I'll have to look around and find out if it'll fit;D I'm pretty sure the CPU cooler should fit. Upvote 0 Downvote
