Will my parts work together correctly?
Jun 11, 2018
My parts list is as follows:
EDITED (12/6/2018)
https://www.pccasegear.com/wish_lists/826567/Project%20Joseph%202019
CPU: Intel Core i7-8700
CPU Cooler: Deepcool Gammaxx GT RGB CPU Cooler
MOBO: ASUS ROG Strix Z370-E
GPU: ASUS ROG GeForce GTX 1070 Strix Gaming 8GB
RAM: Team T-Force Night Hawk RGB 3000MHz 16GB (2x8GB)
SSD 1 (for OS): Samsung 970 Evo 250GB M.2 NVMe SSD
SSD 2 (for games & files): Samsung 860 Evo 500GB SSD
HDD (for video and music): Seagate Barracuda 2TB ST2000DM006
PSU: be quiet! Pure Power 10 600W Power Supply
Case Fans: Deepcool RF-120 RGB Fan 120mm 3 Pack
Case: Phanteks Eclipse P350X Tempered Glass D-RGB Black
OS: Windows 10 Home 32bit/64bit USB Drive
Additionally: 2 x Cooler Master 1-To-3 RGB Splitter Cables and Phanteks RGB LED Adapter Cable
I'd like to connect my: CPU Cooler, MOBO, GPU, RAM, Case Fans and Case with Aura Sync
I'd like to run games at over 60fps 1920x1080p at highest settings, animate using Adobe Flash/Animate and do some basic video editing with Premiere Pro and Camtasia Studio 9. I'd also like to use Office 2016 and do some web browsing and video watching.
Thank you.
(from Australia)
1. Living in US?
2. Major usage other than gaming?
3. Cooler is overkill, MB has cheaper alternative but you want AURA sync. I have heard stories AURA sync interfere with some funcitonality. PSU can be cheaper but better since 550 is more than enough for the build. Not fan of inwin cases, EVO is more than enough for gaming/normal usage.
Not a fan of constantly cycling rgb colors in the case. Having static fixed colors is better in my personal opinion. To that effect :
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor ($239.00 @ SuperBiiz)
CPU Cooler: NZXT - Kraken X62 Rev 2 98.2 CFM Liquid CPU Cooler ($146.33 @ OutletPC)
Motherboard: MSI - Z370 GAMING PRO CARBON ATX LGA1151 Motherboard ($155.66 @ B&H)
Memory: Team - T-Force Delta RGB 16GB (2 x 8GB) DDR4-3000 Memory ($169.99 @ Newegg)
Storage: Crucial - MX500 500GB 2.5" Solid State Drive ($109.95 @ Adorama)
Storage: Western Digital - WD VelociRaptor 1TB 2.5" 10000RPM Internal Hard Drive ($218.00 @ Newegg Marketplace)
Video Card: EVGA - GeForce GTX 1070 Ti 8GB SC GAMING ACX 3.0 Black Edition Video Card ($489.99 @ Amazon)
Case: Fractal Design - Meshify C Dark TG ATX Mid Tower Case ($89.99 @ SuperBiiz)
Power Supply: SeaSonic - FOCUS Plus Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($74.98 @ Newegg)
Operating System: Microsoft - Windows 10 Home OEM 64-bit ($95.89 @ OutletPC)
Case Fan: Thermaltake - Riing Plus 12 RGB TT Premium Edition (3 Fan Pack) 48.3 CFM 120mm Fans ($85.58 @ Amazon)
Total: $1875.36
Generated by PCPartPicker 2018-06-12 00:59 EDT-0400
Kraken X62, best aio for lighting hands down.
Delta rgb rams looks as good as trident z rgb but costs a bit less.
Gaming pro carbon has the right rgb effects in the right place to be actually visible and not be gaudy like the aorus from gigabyte.
Evga cards also has lit evga and GeForce lighting in the side and is just the right amount imo.
Now the one thing that got a bit extra rgb are the fans. Rgb visible on both the front and side face of the fans and perfect if placed 2 in the top and 1 in the rear.
The tinted TG of the case also displays the rgb brilliantly while not disturbing u sitting in the side.
Just add a led strip to highlight the case a bit and you are set!
Whilst I appreciate your ideas, suggestions and for putting the effort into forming a parts list for me, RGB is a very important part of the build to me and I would like the option to have them cycle and flow through Aura, if not Corsair Link.
Lucky_SLS and vapour, what do you two think of my updated parts list?
I removed wasted money from:
Corsair fans (CPU cooler was overboard as vapour mentioned and I only chose the case fans since they had LNP to sync with the AIO)
The In Win case which vapour also noted wasn't so happy with
Overboard PSU
Pro SSD
And used that money to upgrade:
My CPU (now i7-8700)
My storage (now super-fast boot and more SSD)
I saved a few hundred dollars
And everything is Aura Synced
Am I good to go?
You can remove the 970 Evo. Sata ssd is more than enough for gaming and 500gb is enough for both games and os mostly.
Spend the saved cash on 8600k, 1070ti gpu and a more beefier cooler like the coolermaster ma620p and a better psu like the evga g2, g3 or seasonic focus plus or corsair txm 650w
