Will my PC build work as expected?
opscopez
13
Hi.
I just built my own custom PC build via pcpartpicker.com and I had myself and my friend look it over real quick to make sure there were no incompatabilities, but I'm really, really new to this and I wanted to know if my build will work as expected.
The build: http://ca.pcpartpicker.com/user/OP-SCOPEZ/saved/mkZzK8
By expected, I mean, it will function properly and will be powerful. E.g. it won't overheat, crash very little, etc. I also ask that if someone could quickly check to make sure that all the parts will fit and will any additional pieces be necessary for the build, e.g. sound cards, connector cables, etc?
Thanks for your time,
opscopez
P.S. The build parts should be available in Canada, so when you're in the pcpartpicker website, you might wanna just briefly change the country to Canada and not United States! :)
No worries mate. Don't mind click the "Pick solution" icon...
Not sure if I will be overclocking, but it certainly is a possibility. I also intend to record videos of me playing, so the 16GBs of RAM will be needed.
I know it says that there are no incompatablities, but what if any part exceeds any dimension of its parent part? Like the video card can't fit in the whole case or something like that. That's what I'm worrying about.
The graphics card will fit definitely fit I your case. Your processor is an LGA 1150 which will fit in your mobo as well.
Ummm, I dot think there's anything else.
Alright. Thanks. :)
No worries mate. Don't mind click the "Pick solution" icon so others who are in the same problem can find this helpful. 😉
