Hello,
I'm new to the whole building your own PC.
I recently bought a new Graphics Card: Asus AMD Radeon R9 270 DirectCU II OC 2GB GDDR5
and had to upgrade my current supply which was 300W to a EVGA 500B 500W 80+ BRONZE.
After installing my new powersupply I was really excited to power it up however it didn't.
These are my current specifications of my PC:
Processor: AMD Athlon 64 FX
Processor Speed: 3.9GHZ (Overclock: 4.2GHz) Quad-core
Socket: SocketAM3+
RAM: 8GB
Computer memory type> DDR3 SDRAM
HDD: 1TB
Integrated Graphics Card: 1GB
I think that's all the details I can provide?
When fitting the new supply I took a picture of all the connections to make sure I made the same connections to the new power supply.
Also if this helps, when I turn on the power supply there is a current running to the new GFX card because the LED PCI-E is lit GREEN.
So maybe it is my motherboard that can't take the change in 200W?
The motherboard is a: A55M E33
Thank you
Socket: SocketAM3+
RAM: 8GB
HDD: 1TB
Thank you
