will my pc configuration work
luisreyes1029
Power supply
Rosewill ARC 750 Continuous 750W@40 C degree 80Plus Bronze Certified, Single +12V rail, SLI Ready, CrossFire Ready ATX12V v2.31 & EPS12V v2.92 SLI Active PFC Power Supply
motherboard
BIOSTAR TA970 AM3+ AMD 970 + SB950 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
ram
G.SKILL Value 4GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C11S-4GNT
cpu
AMD FX-8320 Vishera 8-Core 3.5GHz (4.0GHz Turbo) Socket AM3+ 125W Desktop Processor FD8320FRHKBOX
graphics card
SAPPHIRE 100364TXSR Radeon R9 270X 2GB 256-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
storage
500 gig segate hardrive
Will this configuration work
PCPartPicker is website that tells you...
PCPartPicker is website that tells you what parts are compatible, try that website out. Anyways yes, it will work.
