Will my PC parts work together?
trevoro0000
19
Im a currently buying parts for a pc but I dont know if these parts work together. Can someone tell me please!
CPU: AMD A10-5800K
Power Supply: SeaSonic S12II 430B 430W
Motherboard: ASUS M5A97 LE R2.0 AM3+ AMD 970 + SB950 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
Video Card: EVGA 02G-P3-3733-KR GeForce GT 730 2GB 64-Bit GDDR5 PCI Express 2.0 Low Profile Ready Video Card
Hard Drive:Seagate Hybrid Drive ST1000DX001 1TB MLC/8GB 64MB Cache SATA 6.0Gb/s NCQ 3.5" Desktop SSHD
RAM:G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
Case: Fractal Designs core 1000
I really need help because I dont want to buy it and then realise I did it wrong! If they dont work together what do you suggest I do?
Oh, I didn't even realize that the case you initially selected is too small for the motherboard.
I left room for a case as I don't pick cases. Just make sure the case supports ATX or mATX boards.
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor ($107.98 @ DirectCanada)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard ($69.99 @ NCIX)
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory ($84.90 @ DirectCanada)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($49.89 @ DirectCanada)
Video Card: Asus Radeon R7 260X 2GB DirectCU II Video Card ($109.99 @ Memory...
There are some compatibility issues. The CPU you chose won't work with the motherboard you chose. An AMD 10-5800k requires a FM2 socket. The motherboard you have uses an AM3+ socket. (Circle in a square hole)
Everything else is ok. It's a pretty low end PC. Don't expect too much. A 730GT is pretty much entry level.
What are you looking to spend?
Im looking to spend around 575 cad (maybe upto 600 cad) I'm really new to this so I'm not sure what parts to pick do you have any suggestions?
Video Card: Asus Radeon R7 260X 2GB DirectCU II Video Card ($109.99 @ Memory Express)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($55.99 @ NCIX)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer ($17.09 @ DirectCanada)
Total: $495.83
Generated by PCPartPicker 2014-11-29 14:01 EST-0500
So here's a build with room to grow. You can swap out the i3 for an i5 later down the road (or now if you have the budget). It's a better GPU than the 730 by miles but will support medium graphics @1080.
I cant seem to find the exact same video card will the ASUS Radeon R7 250 1000MHZ 1GB 4.6GHZ GDDR5 DVI HDMI VGA PCI-E Video Card work too?
