Will my pc work on 480 Watt PSU?
Juggernaut3-9
I wanna know just to keep in mind in case of something might happen, will my pc work with 480 watt psu? Specs:
- Desktop Motherboard
- Intel Core i3 530 2.93 GHz (x1)
- nvidia GeForce GTX 770 (x1)
- 4 GB DDR3 RAM (x3)
- DVD/CD-RW Combo (x1)
- 1 PCI Express x16 slot
- 3 Fans
- 2 HDDs
- 2 USB Devices
So what do you think? if it doesn't work will it work on 500 Watts? Please help me here because i can't get the psu's with high wattage due to some problems :/ Thanks in advance
I would highly suggest that you go for the 500 watt PSU. The GPU already consumes around 230 watts the CPU uses around 75 watts. It is also suggested from the GPU website that the PSU should be able to go up to 500 to 550 watts. If you are planning on upgrading this build within the future, then a 500 watt (or even more) could help. Going for the 480 watt power supply is a risk, but it could work. Just be careful because if you don't have wattage available for you system, you could fry your whole build.
http://www.guru3d.com/articles_pages/msi_geforce_gtx_770_gaming_review,5.html
Here is Guru3D's power supply recommendation:
GeForce GTX 770 - On your average system the card requires you to have a 550 Watt power supply unit.
GeForce GTX 770 2-way SLI - On your average system the cards require you to have a 750 Watt power supply unit as minimum.
GeForce GTX 770 3-way SLI - On your average system the cards require you to have a 1000 Watt power supply unit as minimum.
If you are going to overclock your GPU or processor, then we do recommend you purchase something with some more stamina.
There's basically no cost difference between quality 550 and 650 PSUs. the Seasonic S12 620 will be likely the least expensive option .... also check the XFX Core Edition 650 and Seasonic M12.
