Question Will my Power Supply be enough?
23T0X1N
8
Will a 500w Bronze rated Power Supply be fine with a Ryzen 5 5600x or Ryzen 5 3600 paired with AMD rx 6600 xt GPU? I am not able to upgrade my Power Supply once I upgrade my CPU and GPU but can later on. I'd like some Power Supply recommendations after I do the upgrade of my GPU and CPU. My motherboard is a Micro-ATX B450 if this matters.
See Brother.. Powersupply are build differently from inside.. 80+ Bronze doesn't represents a thing about quality.. I never used EVGA PSUs.. only used Deepcool, Antec, EVGA, Coolermaster, Corsair..
And My 2 favourite Budget PSUs are Coolermaster MWE 550v2 Bronze and Corsair CX550F RGB..
Both are superb when it comes price to performance..
My analysis shows Voltage stability is also good.. and are almost equally reliable..
You can ask me exactly why I said about those PSUs.. i can explain..
Um?
Yeah not all
"bronze units are bad" That being said in the last 5+ years almost all bronze units from any manufacture end up in lower tier via ranking. Generally units are built which much cheaper internal components. It really doesn't take much to get to 80+ gold at this point in time.
Um?
Yeah not all
Typing Mistake.. I was going to write NZXT Instead of 2nd EVGA...
