Hello, I have a machine that I'm looking to upgrade Specifically the GPU's. The upgrade will be either 2 Nvidia Evga GTX 780 Ti's or 2 Nvidia Evga Titan Blacks I will leave a list of parts that I'm currently using below
CASE: Thermaltake Chaser MK-1 Full Tower Gaming Case W/ Side Panel Window
Disk: LG 14X Internal Blu-ray Burner, BD-RE, DVD+RW, 3D Playback
CPU: Intel(R) Core™ i7-3820 Quad-Core 3.60 GHz 10MB Intel Smart Cache LGA2011
Fans: Two Maximum Enermax 120MM Case Cooling Fans with Blue LED, also Four 200mm Blue LED Fans
Cooling: Thermaltake Water 2.0 Pro Liquid Cooling System 120MM Radiator Single
HDDS1-2: Two 240GB Corsair Force GS Series SATA-III 6.0Gb/s SSD - 555MB/s Read & 525MB/s Write
HDD3: 1TB Western Digital Caviar Black SATA-III 6.0Gb/s 7200 RPM HDD
MEMORY: 16GB (4GBx4) DDR3/1866MHz Quad Channel Memory (Corsair Vengeance
MOTHERBOARD: (4-Way SLI/CrossFireX Support) ASUS Rampage IV Extreme Intel X79 Chipset Quad Channel DDR3 ATX w/ ROG Connect, BT GO, OC Key, Subzero Sense & 7.1 HD Audio, Intel GbLAN, 5 Gen3 PCIe X16 & 1 PCIe X1
POWERSUPPLY: * 850 Watts - Corsair CMPSU-850TXV2 80 Plus Power Supply - Quad SLI Ready
My current GPU's are as followed
Two NVIDIA GeForce GTX 670 2GB 16X PCIe 3.0 Video Card (EVGA FTW Edition) Sli
-Thanks in advance!
-Thanks in advance!
