Will my PSU fit
From every picture I've seen it does actually look like a standard atx psu is there (albeit a short one)
Open the case , measure the PSU itself .
Post the measurements here.
If it will take an atx PSU then the vs is not the unit is buy honestly , its a new model so nor entirely sure of its quality but if its anything like the older vs series it won't be very good
^ take the side of the case off so you can see the psu.
Measure its length from where It touches the back of the PC case to the opposite end where all the cables come out of it.
In cm call that length
Measure its height from top to bottom
In cm call that height
Measure its width from one side of the case to the other in cm
In cm call that width
On the back of the case the psu should be fixed with 4 screws , measure the distance between the centre of the top 2 screw's in cm.
Measure the distance between the top left screw & the bottom left screw in cm.
Post all 5 of those measurements back here.
