Will my PSU power some components
Griffin389
11
Hello everyone,i have a question,i currently own the Cooler Master silent pro m2 1000w PSU,and my qusetion is will it be enough to power up : the Amd fx9590 ,Sapphire R9 290X ,3 internal HDD;s 4 internal fans,1 liquid cooler corsair h80i ,and 4 external usb's hard drives with 3 having own power supply only one is using PC's power.Thats pretty much it,also running a windows 7 64 bit.
Sweet ! Thanks alot lewisaro1 and ServiceDroid_R, i am not planning dual GPU,was a bit concerned but now i feel more confident and i will move in on this upgrade ! Thanks for the assist guys !
Thanks expl0itfinder and odiervr too :) And guys i have another question,im a bit concerned,the Corsair H80I should be enough to cool the fx9590 on stock speeds?? i dont intend OC on the CPU since i already read that is a 8350 oc'd.
Yes, that would do a fine job. It may get a tad noisy under load, but that's what you sign up for when you buy a 4.7/5.0GHz processor
Yeah i thought that something like that may come,i just haveto crank up the speaker volume or get good headphones that isolate well the outside noise.
Thanks for the heads up expl0itfinder :)
