Will my PSU work in Europe?
fireclaw20
20
I live in Europe and recently bought a PSU from newegg (https://www.newegg.com/global/be-en/Product/Product.aspx?Item=9SIA6ZP5R69060&Description=EVGA%20650%20b3&cm_re=EVGA_650_b3-_-17-438-121-_-Product)
Ofcourse I completely forgot that in America there is a different system. Will this PSU work in Europe if I just get an European power cord or will I need to return it?
Yes a PSU will work in any country, the only difference will be the power cable it comes with. For example the power cable of a PSU in USA is different to a power cable in Europe.
If for whatever reason you receive a PSU with a power cable that doesnt fit in your country's power outlet you can simply buy a new power cable at any local electronics shop & they are very cheap.
All the best
All the best
