Will my rx 470 go well with my current specs?
Paolo_4
Commendable
Jan 12, 2017
Hi guys i have i5 4460 with msi h18m-p33 motherboard and i am planning to buy XFX RX 470. What do you guys think?
Addtional question: What PSU will be the best with this build?
I only still have 1x4g ddr3 hyperX 1600mhz. Should i get another 1?
Yes the RX 470 would perform to it's fullest in your system, but yes you need at least another 4GB of system memory. Might as well get the same exact RAM and run it in dual-channel.
A decent 450-500W power supply should be sufficient. It really depends on your budget.
If on a tight budget something like this.
If you want a higher quality unit, then this.
And if you have plenty to spend, then something like this.
Well, the easy answer is yes and yes. The rx 470 will go good with it as long as you get another stick of ram so ou havfe 8gb.
However, if you have some money to upgrade and want more detailed advice, please give me your complete specs and parts list, preferably using a pcpartpicker list.
