That refers to the PCIe lane on the motherboard. In the specs it lists what each lane runs at, generally the first slot runs in x16 mode, and the second can run in x4 or x8 (both lanes would be x8 then).
Hi,
Please tell us Your computer specifications:
Motherboard: brand and model?
Processor: Brand and model?
Memory's?
Chassis: Brand and model?
Etc.
So that we can give some advice how and what to upgrade - and if its necessary.
Best Regards from Sweden
There is no compatibility issue, all PCIe standards are backwards compatible. meaning you cold run a PCIe 3.0 card on a PCIe 1.0 slot. The card will just run at the speed of the slot. I'm running a card that is PCIe 2.1 in a PCIe 1.1 slot in my old computer and it runs perfect, it just doesn't have the full speed it would if it had a matched slot. My current computer (in my sig) has a 3.0 card in a 2.0 slot, no issues, full speed for all intents and purposes.
To clairify EVEN PCI-E x16 1.0 would even be more than enough bandwith for a "GTX TITAN P" there backward and forward compatible, and really 2.0 and 3.0 cant even be fully utilized as with PCI-E x16 1.0, the versions are mainly enhancements to ensure bandwitdth will never be too little provided that the slot conforms to PCI-E SIG standards.
I am planning to buy a Amd RX470 which uses a Pci-e 3.0 standard.
Can you please tell me if there is a compatibility issue and if not it will run slower , by how much slower.
will it be better for me to get a new mobo as well , or it should be fine.
I am planing to play game at 1080p and not 4k or VR.
