I ImplicitWeevil Honorable Feb 9, 2014 27 0 10,530 Jan 11, 2016 #1 Will a EVGA GTX 960 4GB (04G-P4-3966-KR) fit in my Carbide 200R case? Also, is it compatible with my ASUS M5A97 R2.0 AM3+ motherboard and Seasonic M12II 620? Will it be a problem that I'm using a AMD processor? Thanks
Solution Barty1884 Jan 11, 2016 Should not expect a bottleneck with an FX-6300 + GTX960 combo. Discussed here: http://www.tomshardware.com/answers/id-2538834/amd-6300-bottleneck-gtx-960.html
Barty1884 Retired Moderator Apr 16, 2015 22,254 1,355 108,740 Jan 11, 2016 #2 It'll fit the case, and work fine. AMD processor won't cause any issues, but depending which one you have, it might bottleneck a bit during some games. Upvote 0 Downvote
I ImplicitWeevil Honorable Feb 9, 2014 27 0 10,530 Jan 11, 2016 #3 Awesome, thanks! Just wanted to double check. Oh, I have a FX-6300 running right around 4ghz. Upvote 0 Downvote
Barty1884 Retired Moderator Apr 16, 2015 22,254 1,355 108,740 Jan 11, 2016 Solution #4 Should not expect a bottleneck with an FX-6300 + GTX960 combo. Discussed here: http://www.tomshardware.com/answers/id-2538834/amd-6300-bottleneck-gtx-960.html Upvote 0 Downvote Solution
I ImplicitWeevil Honorable Feb 9, 2014 27 0 10,530 Jan 11, 2016 #5 YAS; this I like to see. I guess they were rocking the 2GB version, too. Thanks for the help! Upvote 0 Downvote
