[SOLVED] Will my system bottleneck?
forwardyt22
16
So I am getting a new rig, however, I am not sure if this will bottleneck.
Specs:
Ryzen 3 2200G @ 3.5Ghz
Gigabyte B450M D3SH
HyperX 8GB DDR4 @ 2400Mhz (overclocking to 2993Mhz if I can)
120 GB SSD and 1TB HDD
MSI Radeon RX 570 8GB DDR5 DX12
Just want to know if anything will bottleneck
However my previous rig was a 1400 and RX480 so possibly might be the same performance.
Thank you!
it will be a good match, not a cpu bottleneck i wouldn't think. on the other hand i would suggest you get a 1st gen 1600x for the same price. the 2200g is very VERY budget in my opinion. it has nearly terrible clock speeds and is in my opinion only good for those people going for a 3-400$ build. you will be better of with 2 more cores and slightly higher frequencies.
If you were on a R5 1400, why did you swap for a R3 2200G? You're in the same region as prior albeit the processor was better with the R5. You also forgot to mention the make and model of your PSU as well as it's age.
Moved thread from Components to Systems.
