[SOLVED] Will My System Bottleneck?
Sunny Neuroxa
18
Hi, want to ask whether my system will bottleneck?
specs:
Core i5 8400
evga rtx 2070 xc ultra
16gb ddr4 2400mhz ram (8x2)
860 evo 1TB
650W psu
1080p 75hz display
I want to know, if any component will be bottlenecked by other components.
Thanks in Advance
At 1080p your cpu will be the limiting factor when paired with a 2070 but with a 75Hz monitor it doesn’t matter, you will get more than 75fps. Actually the limiting factor is your monitor, you could happily run a 1080p 144Hz or 1440p 144Hz, the cpu will hold you back at 1080p 144Hz but probably not enough to worry about it.
Reactions: Sunny Neuroxa
D
Deleted member 14196
Guest
Yes that’s kind of how I felt I would bump the processor up a little bit if you have problems after you get your GPU
Feb 26, 2019
Yes, do you think i7 8700 would suffice? Overclocking's not my thing, so I'll stick to Non-K chips.
You could probably get away with even an i5 8600k, it's a powerhouse of a chip and wouldn't bottleneck your rig in this case. (The K skew also has a higher base and boost clock than it's non K skew, without overclocking.)
