Will my system handle R9 280X?
ChongWiz
41
I currently use an XFX HD6870, but I plan on upgrading to an R9 280X, specifically the Sapphire R9 280X Vapor-X.
My specs are:
CPU: AMD FX6100 Turbo 3.9GHz
RAM: MEMSeven 8GB DDR3 PC-1333
MOBO: ASUS M5A78L-M
PSU: 600W LC-POWER Silent-Deluxe
I don't see a problem with it other than your PSU. It's not that the PSU definitely won't work, but it would highly advisable to grab maybe 700W+ PSU for something that powerful. That card alone is rated at about 225W by itself.
You should be adequate power-wise if this is your PSU: http://www.lc-power.de/index.php?id=45&L=1
Your 600W PSU has 2 x +12V rails rated at 38 amps total. Enough for that 250W card, 125W CPU, and a normal system. The only problem will be the fact that the PSU has 1 x 6 pin and 1 x 6+2 pin PCIe cable. But the card requires 2 x 8 pin.
If you go with an adapter to power the card temporarily, I'd suggest looking into a slightly bigger PSU with 2 x 8p PCIe cables.
Wattage- and ampere-wise, the PSU is fine. However, you will be short one 8-pin PCIe power connector, which you would have to fix by buying a molex to 8-pin adapter cable. The PSU is not one of the top brands out there so I would not talk about its reliability. If at all possible, I would upgrade to a better brand such as Seasonic, XFX, PC Power & Cooling, Antec, Corsair.
Thanks to everybody for the fast help, I bought the card and the adapter shown by clutchc, I will buy the XFX PSU if it will not work properly, I'll update this post telling wether it works or not, it might be helpful to others with the same problem later.
Post an update on how it runs because I was planning on buying a 280x witha fx-6100.
Post an update on how it runs because I was planning on buying a 280x with a fx-6100.
