I bought a new computer that should arrive soon.
The graphics card will be a MSI GTX760 4GDDR5 card, which has only DVI-I,DVI-D, HDMI & DP outputs.
My monitor on the other hand has only a single VGA input.
I bought a DVI-D DL to VGA adapter but on my current card's DVI out (GeForce 9500GT) I couldn't get any output.
the cable I was using was single link and the adapter / card was dual link though, if that matters. (also I should note the card was DVI-I but works perfectly with a DVI-D to HDMI cable)
There's a chance that the cable is just bad since I don't have any other DVI devices to test it on, but I heard that the graphics card must support analog output for the VGA adapter to work.
So- will my new card work with the adapter? also, should I buy a dual link cable for it?
