Will my XFX 5850 fit my medium ATX Lian Li
It'll be snug. you should be able to get it into a standard-sized Mid Tower ATX case with just enough room to get some cables around it. Make sure you get the power cables plugged into before you put it in the slot though. It's going to be tight
