When I measured my XPS 420 case where the psu is, it seems as though it would only fit a PSU with a width of 5.6 inches maximum (though it's a hard angle to measure with my current PSU in there, I'm pretty confident my measurement is correct). However, most forums say that any standard ATX power supply should work in the xps 420. This is the PSU I've been eyeing: http://www.newegg.com/Product/Product.aspx?Item=N82E16817438048&cm_re=evga_power_supply-_-17-438-048-_-Product
I'm upgrading so that I can swap out my 9800 gt for a gtx 960 mini, but I'm concerned this PSU won't fit properly. Has any one had any experience with this that can confirm concretely that it will fit? Thank you so much in advance for your time and any help!
